Beetyboop..
Now, i know you are having a stab at designing this installation, but honestly, you are wasting your time.. Whoever goes to install it, will obviously want to do all the cable sizing and the myriad of other calculations themselves for the following reason; They know full well, that if they install the thing as YOU have designed, AND and at final inspection it does not comply, [more on this later] then, they WILL NOT energise the thing, and you will not be a happy bunny, and presumably refuse to pay them.
Now, as anyone capable of doing the design work will obviously have the common sense to realise this, they will want you to sign, as BS7671 requires, that YOU PERSONALLY are responsible for the design. IF THEN it turns out not to comply, they will sue you to get paid AND WIN. But who wants the hassle???
Nobody sensible will do it....
So you say you got an HNC in mechanical engineering?? So tango'd what, there are people on here with TWO degrees, one in electrical and one in mechanical..
Now, you seem to be a bit "hung up" on this idea of "final inspection" You do realise that it does not quite work like that, the process of inspection is a continual one all through the process of actually installing stuff. You do not just complete an installation then fart about with a meter for a bit and pronounce it is "ok" It is not as simple as that.
So, as i have shown, the installer will have do do all the calcs anyway, so you are not going to save anything, just complicate matters..
Stick to what you know.. I can calculate deflections of beams, reactions at the ends, and do BM diagrams, BUT, this does not mean i am a structural engineer and can design bridges..[Hmm, now what is this web bearing and buckling business all about]
Just let the electrician do it all. and then, if it DOES go tits up [unfortunate choice of words!] YOU will be in the clear. Get it wrong and you may well indeed end up "tits up".....
john
