pon
Hi, I'm hoping someone can reassure me that what I'm about to do will be fine!
I am linking 10 bulbs together to create an indoor lighting feature. I am using 10 x 25watt SES bulbs. I am using a power cord with a max rating of 240v 8amps and a plug with a 3amp fuse.
I am linking the bulbs as follows -
Live wire in to one terminal of lampholder 1. Live wire out of same terminal in lampholder 1 to terminal in lampholder 2. Live wire out of same terminal in lampholder 2 in to lampholder 3 . . . and so on until all 10 are connected. Neutral wire to be connected the same way to the other terminal in each lampholder.
Assuming this is ok so far, is the following correct?
The current over one bulb is 25w/230v = 0.1 amps therefore the current over the whole circuit is 250w/230v = 1.08 amps. My power cord with its Max 8 amp rating is sufficient and coupled with a 3amp plug fuse, the end product will be safe as well as decorative?
Many thanks in advance. I should point out that I am not an electrician if you hadn't guessed.
