If that's the house end then scrap my Q.
We need a bit more info.
Clearly on a 40m cable working something a bit more juicy than a flymo, a battery charger and a 100w lamp there is a bit of calculation needed around the expected max demand in order to check the right size cable is used...Im a carpenter and joiner mate . I just do wood stuff and have no idea about electrics . When the electrician turns up on site he normally turns the power off so i go home .
The BAOS has a 3hp motor, trust me, I have one in the back of the van that's goosed!I can get all the rating plate details off it later, but it is the 3ph version.
I would still need to upgrade the supply to do that though woudnt i ?Could you go back to using a 3 HP, 3 Phase motor with a single phase to 3 phase inverter so you could 'soft start' it say over 4 seconds and as the inverter will probably use PWM it will limit the start current as I understand it. Of course I know we are talking more cash here and moving away from the original OP question, but it is late and I am thinking out loud.
