Mark2spark
- Mar 25, 2008
- 269
- 1
We could even get into a 60's wired house with no cpc if you want
id say just the part your install. but in some cases, its quicker & easier to make the entire circuit complyI would have thought that, when you alter or amend a circuit, at least that WHOLE circuit should be compliant; or noted as a deviation.KME
did the circuit even need RCD'd?Sorry to butt in, but if what you've stated is the case, when I added an emergency light fitting (yesterday), should I note the fact that the particular cct I altered is NOT RCD protected?Or am I missing the point :coat
Incorrect - rcd protection is only applicable to your installation work. The IET are peddling the "whole circuit" drivel as a political tool against the ESC/NICEIC who are responding in kind.I would have thought that, when you alter or amend a circuit, at least that WHOLE circuit should be compliant; or noted as a deviation.KME
