12V Actuator - 50Mm Stroke
Riggy
Feb 29, 2008
1,019
The Eden Valley, Cumbria.
Don't want to bore you with details of why, but a customer needs to automate the starting of a generator in a remote location. Switching ignition and starter is easy enough, but I didn't think about the manual choke!
So, I'm looking for 12Vdc solenoid/actuator with a 50mm stroke, not a lot of force needed, any ideas/suggestions?
Without looking through the RS or Farnell's cataloges  a cheap car central locking actuator could be made to give the correct stroke by altering the pivot point.
An example http://compare.ebay.co.uk/like/300735248596?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&adtype=pla&crdt=0
wish i thought of that the other year when i made altered mine to electric start. ended up with a metal rod to the front of the case so i can get at it. although it doesnt get started remotely, the start button is right next to it
