I have had a go at answering these does anyone know if they are correct?Q1. A Hall measures 13m x 15m with a light loss factor of 0.65 and utilisation factor of 0.75. It is to be luminated to a level of 500 lux, the total lumen output will be:
a) 400
B) 69642
c)97500
d)200000 ExA/UFxLL
Q2. If a single loop of wir forms the armature of a single d.c generator, the emf, generated in one of the coil is given by the formula:
a) e = 2Φ60/Np
B) e = 2N/60pΦ
c) e = 2ΦND/60? We have been taught that its E=2pΦNZ/60c
d) e = 2ND/60Φ
Q3. A series a.c circuit has a resistance of 10, inductive reactance 5 and a capacitive reactance 2. The impedance of the combination is:
a) 0.427
B) 4.27
c) 8.3
d) 10.44
Q4. When a circuit having a resistance & inductance is connected to an a.c supply, a current of 10A flows. If the in phase component of current is 6A, the power factor of the circuit is:
a) 0.5
B) 0.6 I guessed its' 10/6 is this correct?
c) 0.8
d) 0.9
Q5. When a single semi-conductor diode is connected across an a.c supply having a peak value of 10V, the peak inverse voltage (PIV) across the diode is:
Does anyone know formula for this?
(I have lost the options for this one - sorry).
Q6. A pure inductor of reactance 50 is connected across a single-phase 230V supply. The power dissipated in the circuit will be:
a) 1058w
B) 105.8w
c) 10.58w
d) 0w
