i have x8 375w JA Solar panels and a Solax inverter - system is 3.03kWh - just one string i believeGeneral rule, if it's not showing a fault, there's nothing wrong. What's your set up, single string, multiple strings and what inverter do you have?
Here's hoping, Geoff!A nice bright January day may give you some re-assurance soon.
they're waking up..Over 220v, looks good to me.
update time | PV1 voltage (V) | PV1 current (A) | PV1 input power(W) | PV2 voltage (V) | PV2 current (A) | PV2 input power(W) | AC voltage (V) | AC current(A) | output power(W) | feed-in power(W) | daily yield(kWh) | total yield(kWh) | feed-in energy(kWh) | consume energy(kWh) | Inverter Status |
2022-12-23 08:45:58 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 08:50:58 | 276.6 | 0 | 0 | 0 | 0 | 0 | 245.4 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 08:55:58 | 282.2 | 0 | 0 | 0 | 0 | 0 | 247.7 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:00:58 | 283.6 | 0 | 0 | 0 | 0 | 0 | 241.9 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:05:59 | 284.7 | 0 | 0 | 0 | 0 | 0 | 244.5 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:10:59 | 287.3 | 0 | 0 | 0 | 0 | 0 | 246 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:15:59 | 285.6 | 0 | 0 | 0 | 0 | 0 | 247.9 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:20:59 | 284.1 | 0 | 0 | 0 | 0 | 0 | 246.7 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
2022-12-23 09:25:59 | 284.6 | 0 | 0 | 0 | 0 | 0 | 245.4 | 0 | 0 | 0 | 0 | 0.7 | 0 | 0 | WaitMode |
Yep.Looks okay team? Wait Mode - i guess this means.. not enough to generate power yet?
Haha!There you go, up earlier than me
Thanks binky.. at the moment, probably only producing enough watts to power the inverter lol..Yep.
Ah! Okay.. thats good.. so the solar is powering the inverter.. and im still in wait mode because not enough power to convert to AC.. I think that's right? - im not generating anything at the moment.. and yeah, its wet and really grey out hereThe inverter works off the DC. My own system is currently generating 53W, but it is a gloomy overcast day where I am. I'm quite lucky in that once my system has fired up, it will run as low as 5W. My system is nearly 10 years old, but I bought the most efficient inverter available at the time.
Try shutting it all down ie turn off AC and DC isolators and restarting. Sometimes that can give the system a little kick to get going. But either way you aren't missing out on much todayAh! Okay.. thats good.. so the solar is powering the inverter.. and im still in wait mode because not enough power to convert to AC.. I think that's right? - im not generating anything at the moment.. and yeah, its wet and really grey out here
its in the roof.. would need to get ladder out etc.. bit of a mare hahaTry shutting it all down ie turn off AC and DC isolators and restarting. Sometimes that can give the system a little kick to get going. But either way you aren't missing out on much today
yesterday it come out of wait mode before now.. hmm i wonder why its not out of it now (I did call Solax and the guy did something his end changed a setting.. maybe that needs doing again perhaps reverted back?)Try shutting it all down ie turn off AC and DC isolators and restarting. Sometimes that can give the system a little kick to get going. But either way you aren't missing out on much today
