Now IMHO that would depend on the requirements for the device...
Cleaning (recommended once a month)
A QUALIFIED ELECTRICIAN MUST CARRY
OUT ALL CLEANING.
1. Before cleaning, isolate the fan completely
from the mains supply.
2. Remove the front cover by pressing the
release catches located on the sides at the
unit with a 3mm screwdriver, whilst pulling the
front cover forward
L
3. To clean the front cover, either wipe it with a
damp, lint free cloth or wash it in warm soapy
water. Thoroughly dry the front cover and
refit.
4. Do not immerse the fan in water or other
liquids to clean any other parts of the fan.
5. Never use strong solvents to clean the fan.
6. Apart from cleaning, no other maintenance is
required.
Yes.Has no one else been to look at an extractor fan that has siezed up (for whatever reason), but with the motor humming like a bee on steriods and as hot as a road side burger vans grill plate?
Surely that alone is a valid reason for installing fan isolators?
A, No as the isolator is for mechanical maintenance.A)If you are arguing you need local isolation in order to replace it, then that argument applies to all electrical accessories?
B)That law IMHO was written to allow safe maintenance of machinery,. and is wrongly being applied to small domestic fans.
I dont agree with this and maintenance is needed/should be carried out.A further thought on this.
The isolation switch is required for MAINTENANCE on a mechanical device.
A small domestic fan works, or it doesn't. If it doesn't it gets replaced. there is NO maintenance work to do
So a simple risk assessment shows no maintenance requirement, and the power of the motor is so low even if you were stupid enough to put a finger in the rotating blade no injury of any note would occur (hence why there are no interlock switches on the "guards")
So I personally am happy to omit an isolator for a domestic fan in some cases.
I think the "test" should be, is there any real maintenance work to do? anything that has serviceable parts, replaceable parts, or requires periodic lubrication or adjustment, needs an isolator. A bathroom fan does not.
THAT admirably demonstrates the "wrong approach" that has been adopted.So where are we with a bedroom type ceiling fan, like fantasia, I have never seen an isolation switch installed for that or ever fitted one.
You go to the fuseboard and isolate the circuit supplying the bedroom fan.
The only likely reasons for being on the receiving end of such disapproval I have already made clear, and as much as I welcome your tired attempts to discredit me, as much as I accept that as the newbie on here I'll have to take at least some stick, it ain't half getting boring now. Move on fella, I ain't your enemy.
Those are interesting comments Mr Skelton; checking your profile reveals you have been a registered member since Mar 2011, over 3 years by my calculation. ("D Skelton Member Since 06 Mar 2011 OfflineLast Active Yesterday, 04:34 PM" Obviously you could also have viewed without registering before this time). And with 80+ posts. I am not sure how you calculate if someone is a newby. Is it time, post content, reputation? Possibly you are not so new after all. If it is so well known to others, (and presumably yourself) that this is a "Cliquey" forum, or the most cliquey as you suggest. Why did you bother coming back here with 3+ years knowledge that it is not the type of environment that suits you. Generally when people consider any environment below their standards they just leave and walk away. Or is it actually a better place than what you are making it out to be? Maybe some of the problem is you just expect everyone to accept every word you say without challenging it and you do not like people swimming against the tide of your ideals.believe me, this place is well known to many many many of those outside of it to be probably the most cliquey of all (not that others aren't cliquey too [but that's just a sad fact of all forums without exception])!
Good call, I like that idea.For what its worth my personal preference at the moment is to use click mini grid with their lockable 3p iso and a fuse carrier if required outside the bathroom door. Neat, cheap and easy.
On some fans the manuf. states that "as far as they are concerned and after all we made the fricking thing in the first place and tested it and all that compliance malarky etc etcetc yahda yahda yahda that it cost us an arm and a leg to get approved.....we advise protecting the fan with a 3 Amp fuse"When off a lighting circuit the OCPD is often 6a and some manuf. say this is too much so advise the use of a 3A fuseI assume the fuses are because you are not connecting to the lighting circuit or its not a 6A B Type Mcb and something else.
....Just asking.....
EX-fricking-ACTLY!But which would blow first a 6A Type B mcb or a 3A Cartridge Fuse.
