sorry KME - missed that part in your post! (thats what happens when you skip parts!); \ ?:| :Y :Y:Y:YFanks, AndyApplaud SmileyApplaud Smiley
get rid of the pressure and you can easily remove the valve without completely draining the systemThe prv is the pressure release valve as mentioned above. You have tested the water upto the boiler you said. So that just leaves the 'other' valve which i'm guessing is a check valve (1 way with arrow on). So even if you took the filling loop off and opened the valve, no water would come back through it. Seems though the system is already low on pressure my next step would be to drain the system down enough to undo the non-tested valve and then open it to test if it is working. My personal thought is that it wont be. Replace if required and fill her back up. Bleeding radiators as per norm. Dont forget that if you completely drain down. Any inhibitor will have been drained down and should be replaced.Looks like it's going to be a chilly xmas.
there will be no pressure so no masive amounts of water coming out. so you could easily stick your thumb over the open end, and turn valve on to see if water is coming through. or you could stick a conex stop end over open end whilst you test the valveThis is true, but water will p1ss out. How does he test valves with his finger stuck in pipe that he has just taken valve off. lol.
not to bad just put extra clothes on still trying to fix the dam thingThought you'd frozen to death mate.
Why do they always break down when it gets cold. I have just had to replace my 25 year old boiler. I am sure the new one won't last half that time though.not to bad just put extra clothes on still trying to fix the dam thing
unless your an OAP, not many people use the heating in summer!Why do they always break down when it gets cold. I have just had to replace my 25 year old boiler. I am sure the new one won't last half that time though.Batty
maybe the boiler just doesnt want to work when its cold? (like me!)Not even for heating water?
