sometimes more
Basically what I said in the very first replyThis is turning into an interesting discussion - IF it can stay civil. So many recent threads have gone bitchy, and been closed / removed. It would be unfortunate if this were to continue......As regards the question itself....If there is a direct like-for-like swap, and the main bonds aren`t in place, I`d STRONGLY suggest they were done. There is a laminated sheet provided FOC by NIC, detailing the necessity for bonding.
IF they refused - I may, in all honesty, do the work. It would depend on so many factors; not least of which is the earthing system.
KME
And a label placed on (or near) CU stating that the specific circuit number has no CPC.If RCD protection and class II equipment is chosen, then this should be noted as a departure on the MWC.
So, approx
The Don's boys took it as their local stable had run out. I'm sure you will get it back, well most of it.Ill have to use your donkey as someone else on here has my horse. :^O
Is that a close variation on the "headless horseman"????? :^OThe Don's boys took it as their local stable had run out. I'm sure you will get it back, well most of it.
I don;t think you could, if it's not specifically disallowed in the BRB then it is certainly against good practice guides. Reason being random CPC's laid in separately could easily be disturbed and disconnected without touching any other cables so the lack of an earth could go unnoticed. I think if you were going to do that extent I would run a 6241Y at least so it would cause a noticeable fault to show up as well.Could you not run a cpc directly from the DB to the class 1 light fitting?
Good point. JI don;t think you could, if it's not specifically disallowed in the BRB then it is certainly against good practice guides. Reason being random CPC's laid in separately could easily be disturbed and disconnected without touching any other cables so the lack of an earth could go unnoticed. I think if you were going to do that extent I would run a 6241Y at least so it would cause a noticeable fault to show up as well.
No you are not.soon as you touch the installation your responsible don't forget.
i normally work it on why its being changed - if its broken & needs replaced, replace it. if they want it changed because they dont like the existing, then it should be done to 17thI've been following this thread with interest as I have to change old brittle pendants in an old property on Friday. I'm pretty sure the bonding will not be up to spec but can't find any definitive guidance. The way I read it is, if the circuit is not being altered or renewed, then no legal requirement to upgrade bonding, but I could be wrong.
Evening Paul b b....Evening chaps,no doubt all been said before but best to confirm!
if a customer wants a light fitting changed and there are no bondings can the job still be carried out wit a note on the cert? also, the same for an rcd?
second q is, if the lighting circuit has no cpc and they want a class 1 fitting (class 1 is metal right?) can i take a cpc from a socket? or is this a nono?
thanks chaps
paul
Hmmm?No you are not.An accessory is being changed, not the circuit.
Yes, a cpc must be available for class I fittings, and if there was not one present, i would not do the job if the client refused to have it sorted.
If it is a class II accessory then no prob.
As has been pointed out, it would not have been left in a worse state than before.
