Am running cable to my garage to provide power for a car charger. The run will be threaded through holes drilled in the center of the joists under the upstairs floor such that the cable is suspended in the air between plasterboard and floorboards. There is no insulation in there.
Would this fall under reference method C, clipped direct? It's uninsulated but still enclosed so I'm not sure?
