dont you start that,!There's no E in Scotch Whisky.Other, inferior, alcoholic drinks might spell it with an E in there somewhere.
good job there is no P in whiskey, isn't it? :slap
Give it a few hours and it will all turn to P....................... :rundont you start that,!good job there is no P in whiskey, isn't it? :slap
I am half way between Liverpool and PrestonIts not the Grid ImpedanceIts not the DNO's Supply
Its the badly designed install
The installer was a Muppet and quite possibly still is a muppet
I suggest you get someone properly qualified and experienced in PV to give you a report for you to take this further and get it sorted at the installers expense
Including a formal written complaint to Napit and REAL
---------- Post Auto-Merged at 19:45 ---------- Previous post was made at 19:45 ----------
Where did you say your were again ?
Good........... I was getting worriedcorrect. you are right, that is where you live,![]()
@ Newmen is there RCDs on the sub board that will/can be influenced by the inverter@NewmanWhen you spoke to Napit did you get the name of whoever you spoke to who stated the install was ok with the PV going into a sub board
Can you refresh my memory of the conversation you had and ideally who you spoke with
@ProDave , I would say the inverter is a distance from the point, the DNO attached the voltage recorder ,"average below 253V" is still a bit vague though isn't it?It's supposed to be 230V + 10% / - 5%
so the maximum allowed is 253V
So just saying the average is below the limit doesn't tell us a lot. The measured average could be 252V and that statement would still be true.
While I agree the installation is at fault, the DNO are not actually helping prove or disprove what, if any, effect the supply impedance may be having on this particular problem.
I think Neal Cumberland (?) covers round this area anyway.@NewmanWhen you spoke to Napit did you get the name of whoever you spoke to who stated the install was ok with the PV going into a sub board
using your earth fault loop impedance meter connect L to L then N to N set L N on display press test button,,, if you have a three wire meter conect the earth to N and L toL and N to N press the test buttonThe DNO would have measured at the service head, that's where there responsibility endsCan you tell us how you would measure the grid impedance ?
I dunno :CWhos Neal?
Heres some of the emails@NewmanWhen you spoke to Napit did you get the name of whoever you spoke to who stated the install was ok with the PV going into a sub board
There is an RDC on the CU in the shop which the electric goes through and there is a RCD on the barn CU where the panels/inverter is@ Newmen is there RCDs on the sub board that will/can be influenced by the inverter
No" earth" just grid/circuit L N impedanceI don't know a lot I must admit and every day is a learning curve for me....So is there a difference between your term of "grid impedance" and what a loop test result gives you?
You must enlighten me as to why I would not know why ?
