What size of cable is that going from inverter to AC isolator. Looks like flex or white FP. But must be small csa to put it through the left hand stuffing gland. Might be getting high impedance through that piece of cable if it's only 2.5 say??
As i remember least on the last SB i fitted you cant get anything bigger than a 2.5 into the connector.What size of cable is that going from inverter to AC isolator. Looks like flex or white FP. But must be small csa to put it through the left hand stuffing gland. Might be getting high impedance through that piece of cable if it's only 2.5 say??
Spoiled my fun...No that was me playing around with posts, and messed up
Dependant on inverter, its usually either 2.5mm or 4mm flex - manuf. spec.What size of cable is that going from inverter to AC isolator. Looks like flex or white FP. But must be small csa to put it through the left hand stuffing gland. Might be getting high impedance through that piece of cable if it's only 2.5 say??
If the "duty holder" or person requesting the work asks a nother to carry out works and the a nother is in this case (I think) MCS,REAL and NAPITregisterd,,,,,, hes ticked the box of negating his """"request for works responsibillity""""Tell that to the electrician who falls from the ladder he shouldn`t have had to climb, when he`s isolating the inverter AC to work on the installation.OH! Thats good to know.
erm....Which copy of HASAWA has that in? I can`t find that particular regulation.
I`ll go along with that - though it DOES give me some preconceptions about the installer![]()
He never HAD a responsibility as installer - but did YOU know that the duty holder has a duty to ensure that the installer is competent? But you go ahead and call it "nonsense" - everyone is entitled to an opinion.
The duty holder can never negate his or her responsibilities. I could provide some HSE prosecution case notes that will verify this but it would prove futile given the fact that you neither state fact nor acknowledge it.If the "duty holder" or person requesting the work asks a nother to carry out works and the a nother is in this case (I think) MCS,REAL and NAPITregisterd,,,,,, hes ticked the box of negating his """"request for works responsibillity""""and I agree there should be a point of emergency isolation but it does not need to be local only clearly labelled and in a obvious location and if you want at the mains location
Please do post your links as I would be interseted in your facts on HSEThe duty holder can never negate his or her responsibilities. I could provide some HSE prosecution case notes that will verify this but it would prove futile given the fact that you neither state fact nor acknowledge it.The worst advise given is by those who are less able to take it.
LOOK can we ALL live the REAL WORLDRegina Vs Octel is a classic example of statute law.There is a classic civil law case which I can never remember, but it is a company something like the "Dancerama shoe company".
Like everything H&S, there are grey areas, however, these two cases demonstrate that HSE will prosecute premises owners/occupiers for the incompetence of their contractors and sub-contractors, and also that the courts take a dim view and will award compensation against companies who go for the cheapest option when selecting contractors.
Remembering that a statute law guilty verdict opens the gates for a civil law award in most situations.
The premises owner/occupier has a duty of care in civil law to select contractors competent to do the work that they require, in this example, then, this can be demonstrated quite easily I suspect to show that the installer was not competent.
Please remember, if it ever goes to court, under H&S law, one is guilty by default, it is one of the few sections of UK law where the burden of proof is reversed.
HSE will say you are guilty of "..." it is then down to you to prove otherwise.
Their expert witness will be well briefed and will make the collective knowledge of this forum seem like that of a 3yr old about chaos theory!
LOOK can we ALL live the REAL WORLDhow on earth can joe public KNOW if their install does not confrom to all relavant regulations untill something goes wrong, by then its to late.
Below is a list of qulifications my installer SAYS he has
MCS AccreditedNeeds re assessing
Renewable Energy Awareness
