Evening all what do you think of the following set up...Its not something I had come across on any jobs thats I have completed so far...
single phase wylex board and a three phase wylex board..
3 phase from the electric meter to the top of the contactor and then from the bottom of the contactor to feed the three phase board..
6 amp breaker in the small wylex board marked up contactor , t&e 1 mm red and cpc (black not connected into the Neutral bar) go into the contactor box the red is connector blocked and so is the CPC , another 1mm2 t&e runs out of the contactor box , the 2 reds are connector blocked as are the CPC , the black from the small db is taped up and the black that is outgoing is in A1 with red sleeving , there is a red link from L1 supply side to A2 ...the outgoing T&E runs to a 3 gang standard switch at the front door and is connected into the switch...
so to summarise the switch switches the contactor which then kills the power to the three phase board..What do you think about having 415 V at a standard switch...as it happens the contactor is welded shut and therefore the switch isnt switching the three phase board off...the 6amp breaker marked up contactor also has an a supply going out to the alarm so despite the MCB being switched off the alarm engineer still had 180 V at source...I know that removing the link from L1 to A2 will kill the voltage but is this a standard set up...
sorry to waffle
sorry to waffle
