Manator
©Honorary Essex Boy™
I do not think it is a farce, if I really wanted I could eliminate the use of RCD socket outlets providing I had a very good reason for doing so and was no less safe if it was excluded. The point of the excersise was to look at the design and see if it can be done, a very expensive rewire could if desired be totally without RCD even on sockets. If you look at any regulation there is often no black and white you can use this to verify your designed circuits.
I have just fitted a fibreoptic lighting system at a very great cost, I do not like it but the clients are over the moon. At no time did I imply to ignore manufacturers instructions about the use of a RCD, indeed if I had to design a house without RCD I would insist on the shower to be fed from the boiler and advise against the use of electric.
All I can say is that it got me thinking, and it looks like some others thought about it.
The question is an exersise, nothing more.
