hi, couple of quick questions;
firstly gridswitches, can you use pvc surface mounted box, couldn't seem to get it to fit grid fram sits to far back?
secondly if a building has an overall 100ma rcd would using 30ma rcbo's in the db overcome the problem of the taking out the whole building under fault conditions in theory i think it should?
cheers
cheers
