"There's a reg quite early in the BGB that basically says that any addition or alteration to an installation must be done safely and that the current installation must be able to safely carry the alteration / addition."
Can the installation carry the alteration/addition? Yes of course it can, the DB itself does not introduce any extra current.
6mm earthing conductor and 6mm to the earth rod is very likely to be ok anyway on a TT system and does anyone know what the earth rod resistance is anyway?
Supplementary bonding is not even needed in a bathroom with the 17th edition these days because the IEE have complete faith in RCDs now, otherwise they would still insist on supp-bonding.,
Only do what you are paid for and give advice for what else is needed. The tenants may feel that since there has not been a problem for the last 30 years and the fact that many of the other houses down the street are the same without even a new DB then there is no rush to upgrade.
Would any of you refuse to replace an out of date DB in one flat in a block, knowing that all the other flats need their bonding upgrading too because you have seen everybody elses supply in the communal mains cupboard? you could
Binky said "would now install 16mm just becuase the house next door might converted from TT to TN-C-S"
If you are still TT then how will neutral current flow along your earth conductors because being a TT your earth is not connected to neutral.
