I might have 4 storage radiators to install in the next week or two. I don't have any details of the job as yet but I'm guessing it might involve a separate CU / time switch / contactor arrangement. Not having done this before, I'm hoping one of the wiser heads on here might take a look at the sketch I've done (link below) and check that I've understood the basic wiring arrangement of the CU properly (or not as the case may be) and point out if and where I've gone wrong.
http://i1341.photobu...iringSketch.jpg
What I'm going for is a 5 amp CPD protecting the switching circuit; then the time switch controlling a 4-pole contactor that will achieve single-pole switching on each of the 4 loads. The load circuits each being protected by its own CPD downstream of the contactor.
A couple of specific questions about this:
1. I know there has to be an air gap between the contactor and the adjacent MCB, but what about the time switch? Do I need a gap there too?
2. As I understand it, contact bounce is a non-issue with resistive non-electronic loads but again, this is new territory for me so I'd be grateful for confirmation that this is indeed the case (or not?).
Thanks in advance,
Tom.
Thanks in advance,
Tom.
