Rewiring to a honeywell L641A1005 cylender thermostat and confused by the voltage readings there.
It's suppled by a Three core and earth in old colours. Red connected to brown on the flex, blue to blue and yellow to earth (although the yellow is not earth so I suspect the installed just used the earth wire on the flex - naughty I know).
Does this wiring sound correct, and what voltage should I get on each wire.
I'm getting 50v on yellow and I think 240 on red. I'm assuming that blue is switched live and yellow I have no idea. Should yellow be 50v, is it be a control wire of some sort? I'm going back to look at why they now have no hot water since I did the rewiring and want to be sure i'm wiring correctly.
