Green and yellow
- Joined
- Mar 2, 2010
- Messages
- 13
- Reaction score
- 0
Hello,friends
I may have a job which has very limited space in a external concrete meter cupboard. From this go three 60 amp submain supplies from wylex switch fuses and one 30 amp. There is also a changeover switch for a 20kva generator.
Its all a bit of a mess due to the lack of space. The meter board takes up the best back wall . The existing switch fuses on the side wall except one.
It would be good to tidy it all up, so I have been looking into dinrail mounted fuse holders. The easiest would be using Ferraz Shawmut 125 amp fuse holders with 22 by 58mm gL fuses, with each having a isolator, every thing in one enclosure. On spec they have IEC 269 and 947-3 and not a BS one. Would that be a problem ? Other than that, using CAMaster HRC fuseholders which needs a bigger and totally enclosed box ? With a separate box for din rail isolators , dont know if it would fit.
Comments/ suggestions please. Cheers
