even on a 6A, your dead.stupidest more like. What if someone plugs their fingers in?
What if someone takes a socket off and sticks their tongue on the livestupidest more like. What if someone plugs their fingers in?
Have you ever tried to see if you can stick you fingers in a socket, bet you carnt.....The BS standard says you carn't for a start..stupidest more like. What if someone plugs their fingers in?
I think you'll find that anyone who plugs anything in that isn't to BS1363 standard are the ones who will be at fault, not the person who installed the circuit.stupidest more like. What if someone plugs their fingers in?
All your what ifs require tools. Only tools needed to tale a plug out are posting above.What if someone takes a socket off and sticks their tongue on the liveWhat if someone finds yor radial under the floorboards and connects a 10kw shower to it
What if all the plugs in the world never needed fuses any more
what if, what if, what if,, give it a rest!!! :yellow card
They aren't mine. They come from HK.This probably includes your fuse-less plugs
Oh dear, remaining shreds of your credibility bad day explodeAll your what ifs require tools. Only tools needed to tale a plug out are posting above.
Between the reduction of the cable size and the device.thats the bit you missed. You install dsso's that have fuses then? Aren't they normally in the plug?
i think the dead burnt to a crisp person maybe of a little more concern than the cable opcornDon't care what happens to the person but what if it causes more than 26A on the cable?
