do you have a link Rod?Using normal cat 5 cable externally is bad practice. Although your circuit will work it is not designed to withstand external environments (weather, temp changes etc) therefore vastly reducing its life.However it is common practice to install internal grade cable in conduit or galv trunking outside.
Got this from cable monkey:
CCS Enhanced Category 5 Solid External cable is the ideal solution if you have to run your cable from building to building.
Suitable for use with Catenarys, in ducts or on the side of buildings.
With excellence performance records, this cable exceeds TIA/EIA Enhanced Category 5 specifications.
- Available in 100 metre , 305 & 500 metre reels
The only difference between CAT5 & CAT5e cable is the test (4 point for CAT5 and 13 point for CAT5e) so go with the cheaper CAT5 option.
how much can cat 6 actually carry over short distances that 5e cant?Tuppeny halfpeny worth, fit cat6 cable and future proof installation. I've been re-wiring my neighbours house, both of which are computer fanatics and basically we istalled hub switches on each floor and ditributed to each point from these. The switches being linked by a single cable, and eventually back to BT incoming point. Don't forget ADSL filter (built into telephone socket) at this point to prvent broadband interference on telephones. This was fitted directly above master BT point. Hope that helps.
External cat 5 is available more so than external bt cable if you put external cat 5e into search engine you get loads coming up link for cable monkey below.do you have a link Rod?though TBH Id go for the 5e variant, see below
I have done a few jobs and seems unless its a big commercial then 5e is more than adequate.
Unless you want to run 1000BaseT in which case cat5 often fails validation for that speed especially on longer runs.The only difference between CAT5 & CAT5e cable is the test (4 point for CAT5 and 13 point for CAT5e) so go with the cheaper CAT5 option.
Interesting point is cat6 is only certified to 250MHz (cat5 is 100MHz) while cat5e is certified to 350MHz. Cat6a though is certified to 500MHz.how much can cat 6 actually carry over short distances that 5e cant?I have done a few jobs and seems unless its a big commercial then 5e is more than adequate.
