I'd be wanting to see a 16mm (or whatever) earth lugged onto the gland plate if there was MIs made off into it... I would be happy with the same on SWAs, but you may as well just use a banjo on at least one of them to provide the point to lug it toThese can be older installations, but see it on newer too, its not the use of the enclosure as part of the earth path that I have difficultly with, properly done it can result in a very solid connection, but rather its two different bits of metal bolted together with 4 poxy self tappers that I hate...
Dont have much of an issue with banjos on the inside instead of outside, but prefer them on the outside unless there is a good reason to do otherwise
Phoenix, Why a 16mm for any MI? A 2 core 1.0mm MI should not require a 16mm tail surely!
I will where possible bend banjo's and not even bolt through the enclosure to eliminate the risk of tampering.
Tampering is to me a good enough reason to put everything where possible inside the electrical enclosure.
The increase in resistance of the banjo due to work hardening when bent is negligible, we don't have to consider the work hardening of wiring when installed so why banjo's.
Oh and yes before anyone questions it copper work hardens when cold and when it is bent full stop, so it work hardens when put onto the cable drum, and work hardens again when taken off, and again when bent into place for use. It is just that the degree of work hardening is negligible.
One reason NOT to use solids, e.g. T&E on vibrating or moving items, and the same for heavy stranded 6491x for the same application.
Fine stranded wires do not suffer the same fate as the work hardening phenomenon is related to the dimensions of the material.
Also, work hardening of copper increases its resistance thus this will increase the Joule heating affect and the R1+R2 & Zs values.
These increases are normally immeasurable with the sorts of instruments that are commonly used for testing electrical installations, but they are present.
Paul
