they should maintain their earth by converting to PME.
not it wont. if it was converted, there would be no earth between DNO earth and DB.... if its connected, then its obvious its still in use.adding a rod could lead the DNO to believe that the instalation has been converted to TT and that it is safe for them to remove their supplied Earth.
As you've not made any attempt to answer the question and have now resorted to insults in private messages, I'll guess I'll just have to assume that you have no explanation as to why you think the extra earth electrode is dangerous.
the questions have all been answered in previous threads.I thought the forum was a place for people to discuss things. I read most threads trying to learn. Clearly some people 'know it all' so why do you need to come on here. I would like to see steptoes answers to the questions asked in this thread as he clearly is knowledgable but no need to insult people and starting blocking eachother. Thought id logged onto screwfix for a second then lol. bad day explode
Could you please point us toward an example?the questions have all been answered in previous threads.
I've located what appears to be known around here as the "great exported earth thread," here:try using the search facility.
I'm not quite sure what you're getting at. Do you mean if the main house is on TN-C-S you consider it dangerous for, say, an outbuilding to be separated as TT? I'm guessing not, since you then talk about parallel paths to earth and the TT outbuilding would not by itself result in such.I dont really care what anyone does with their earthing arrangements but if I was to test a house with PME/TN-C-S and TT/SPIKE mixed in one installation I would have a CODE 1, and possibly even a disconnection of supply noticed served. there is NO way I would/could ever sanction the use of a parallel path to earth for any kind of fault.
mine in redI've located what appears to be known around here as the "great exported earth thread," here:http://www.talk.electricianforum.co.uk/showthread.php?t=483
At one point you stated:
I'm not quite sure what you're getting at. Do you mean if the main house is on TN-C-S you consider it dangerous for, say, an outbuilding to be separated as TT? No, outside the EZ so different installation I'm guessing not, since you then talk about parallel paths to earth and the TT outbuilding would not by itself result in such. correct
So did you just mean it to cover a scenario where the supply to the house is TN-C-S and there's an extra earth rod installed (which does not make it TT,matter of opinion but does result in a parallel path)? but, yes
Not sure about that. When you split the quotes into chunks with correct attributions, and also add multiple quotes into a post in chronological order then you've got the hang of. Currently you're sort of sledge hammering your replies in, which isn't quite 'getting the hang of it'gawd Im starting to get the hang of this quote thingie.
starting to get the hang of it,Not sure about that. When you split the quotes into chunks with correct attributions, and also add multiple quotes into a post in chronological order then you've got the hang of. Currently you're sort of sledge hammering your replies in, which isn't quite 'getting the hang of it' Now, back to this earthing discussion......
Well yes, it is impressive when the older generations manage to get on the internet successfully.Ive only been at this internet thingie for a couple of years, give me a chance,Im doing well to be able to quote or copy, and paste as well,
thanks, :^OWell yes, it is impressive when the older generations manage to get on the internet successfully.
O.K., just wanted to make sure we were talking about the same thing which started this thread.So did you just mean it to cover a scenario where the supply to the house is TN-C-S and there's an extra earth rod installed (which does not make it TT,matter of opinion but does result in a parallel path)? but, yes
