the earthing in your house is now at 230v potential, and you are reliant on AN other to have a suitable protective device to disconnect the fault.How exactly would that cause a danger?
Ignoring the suitable protective device, say there isn't one.the earthing in your house is now at 230v potential, and you are reliant on AN other to have a suitable protective device to disconnect the fault.
its not. its tied to earth.its TNS, so its at 230v
Not so, touch 230V and you will only get a shock, if there is somewhere for the current to flow.its TNS, so its at 230vcos its at 230v
what part of it is it you dont understand?
you touch 230v you could get a shock and possibly die.
THERE IS NO FUSE ON THE EARTH
Im sure that I once read somewhere that that is something to do with how people get electrocuted, could be wrong mind, I usually am.Not so, touch 230V and you will only get a shock, if there is somewhere for the current to flow.In this case, the earth is at 230V, so where will the 230V flow to?
You obviously read it wrong.Im sure that I once read somewhere that that is something to do with how people get electrocuted, could be wrong mind, I usually am.I really must read up on how electric chairs work again, must be something to do with how they strap you in.......
the path of least resistance,
so as long as you can prove that they woman at number 37 died because she was negligent in touching a conductive pipe after coming out of the shower then all is honky dory in cuckoo land.
how many times do you need the term parallel paths explained to you?You obviously read it wrong.Electric chairs work by the current flowing through a person.
Why would a woman touching a conductive pipe be killed? because its at 230v potential
You're the one who believes an extra rod is dangerous.
Why don't you explain why?
how many times do you need basic ohms law explained to you? you will not get 230v unless neutral goes O/C. in which case, even without the rod, you would still have 230Vhow many times do you need the term parallel paths explained to you?Im starting to really give up on simple things like this,
I may well be incompetent, but at least I understand the basics,
like someone wiser than me once said,
anyone can be an electrician,
the difference is knowing how not to fry someone.
To sustain a shock there has to be a difference of potential across two (or more) points of the body. In the electric chair it's done by using electrodes on the head and one or both ankles or lower legs, then applying an initial voltage of about 2000V across them (give or take a few hundred, depending upon the system).Im sure that I once read somewhere that that is something to do with how people get electrocuted, could be wrong mind, I usually am.I really must read up on how electric chairs work again, must be something to do with how they strap you in.......
If you understand the basics, then you should understand, that for current to flow, there has to be a difference in potential.how many times do you need the term parallel paths explained to you?Im starting to really give up on simple things like this,
Considering that we are discussing a PME installation, what does the relationship matter?and please explain to me the relation of N to T in a TNS or TT situation.
I assume you actually mean tn-c-s installation on a pme network?Considering that we are discussing a PME installation, what does the relationship matter?
try this approach steptoe.and please explain to me the relation of N to T in a TNS or TT situation.
Erm. No. A Faraday cage requires a closed conductor so no electrical forces can exist within it. That is not the same as a chicken wire ball so the surface potential is the same but electrical forces can still exist within it.This is the principle on how Faraday cages work.
I actually mean either, as they are the same.I assume you actually mean tn-c-s installation on a pme network?
