We are planning to let out our 3 story house once we move. It’s a 2001 build and has had no changes to the Electrical fittings / Consumer units. We are planning an EICR and want to prepare in plenty of advance before we move out.
The Consumer Unit (located in the garage under the master bathroom) is a Tenby with Legrand Main Switch, MCB’s for all cats and an MK 7860s Dual Pole RCD covering the MCB’s for the Sockets ccts and a HotTub feed.
Q1. The CU is not metal. Do Metal Consumer Units have to be retrofitted to as build properties from 2001 for Private Rental use ?
Q2. The property also has GU10 Downlighter's as built in many / most rooms of the downstairs rooms. They all have LED’s now, but I don’t think they are Fire Rated Downlighters given the 2001 property age. Will all the Downlighters need replacing with Fire rated Downlights for the EICR to Pass for Private Rental use ?
Picture of Consumer Unit attached.
