ELECSA Assessment Job - CU Consumer Unit Change and Circuit Extending
ccfc,
I "always" use the earth DIN rail terminals as it "improves" your "earthing".
They also can be used as end stops as they clamp to the rails!
They are more often than not insulated both sides also.
ccfc,I "always" use the earth DIN rail terminals as it "improves" your "earthing".
But don't they also mess up your ring continuity? ;) Measured from the CU that is!
