Thanks Murdoch - the forum has been very helpful and I have learnt a lot. The ECIR cost £145 +VAT which is a discount rate as he does nearly all the tests for the letting agency. It is only a small flat with 5 circuits 2 of which are rings - the kitchen, 8 sockets, and other rooms 6 sockets..
I had a look online and the cheapest quote I found was £72 and I agree it doesn't seem possible to do it properly for that price. Do the electricians regulating bodies ever do spot checks to see if the tests have been done properly? Anyone know a competent electrician that covers Watford WD17?
The BIG problem is that electrical work is NOT regulated in England... DIY electrical work is legally permitted... Electricians do not have to be members of any voluntary trades bodies... So there is no incentive for any of the trades bodies to do any random spot checks on anyone!
There is a single registered body for anyone working on gas installations for monetary gain..
https://www.gassaferegister.co.uk/
BUT there is NO equivalent single compulsory registration body for electricians.. hence the problem of finding competent tradespersons is the elephant in the room for many types of electrical alteration/addition/maintenance tasks!!
However... for the moment lets just assume you do have a competent person available to undertake an EICR...
Although the type of property will have an impact upon the actual final cost for an EICR, (2-bed, 3-bed, house, bungalow, flat etc), it isn't the only costing factor.
Other key points include:-
- Hourly labour costs vary around the country. (e.g. London more expensive than Sheffield)_
- The accuracy of existing consumer unit circuit descriptions can save a lot of time.
- Availability of copies of previous certificates and/or inspection reports.
- Accessibility and neatness of internal consumer unit wiring and all conductors terminated in correctly numbered terminals in neutral / earth bars, allowing easy identification and testing of circuits.
- If the person undertaking the inspection has previous knowledge of the installation, (e.g. done previous alterations/additions/inspections at the property).
Consider:-
A rats-nest consumer unit with no previous certificates, reports, or consumer unit circuit identification, inspected by a person who has never seen the installation before... (They will have to spend a lot of time establishing the composition of each circuit.)
-vs-
The same property with a neat full labelled consumer unit, previous certificates and reports available, and inspected by a person who has been looking after the installation, (alterations, additions & periodic inspection), for the past 20+years.. They will be able to fly through a full EICR in a much faster time which equals reduced cost!
So the costs will be significantly different.. and expensive may not mean you are being overcharged.. and cheaper may not mean you are not getting a full accurate EICR undertaken..?
Side note: your £72 googled price does seem very cheap.. That price may cover one hours labour.. but not much into the second hour..!? And even for a small installation I would be thinking half a days labour is the bare minimum to do the inspection and then write up the report!
