I thought you were going to say...Erm...Who said to earth? ROTFWL
it is the amps. but unless you get the voltage, you wont get enough current to flow.I thought it was the amps that did the damage though and not the volts?
an isolation transformer has no reference to earth. there is only a voltage between both lives. unless your touching both lives, there isnt a return path, so no shockJust a couple of things I don't completely understand:2) Special Location mentioned above that with the transformer there is no return path to complete a shock through the body - Does a transformer completely isolate the circuit in question?
Yes, but without enough voltage the amps wont be passing through your body to kill you.I thought it was the amps that did the damage though and not the volts?
the amps that something can supply doesnt have anything to do with this. your just adding to confusion by saying a car battery is at 70A but your fine, and then 230v is 50mA. a car battery may be able to supply 70A, but there wont be 70A flowing if you touch it. and a 230V supply is not always a 50mA shockYes, but without enough voltage the amps wont be passing through your body to kill you.You could have a car battery at 12v 70A, touch both terminals and your a-ok.
Now go back into your house touch a live cable at 230v but only 50mA and you could be a dead man. Up the ampage, stand in a field (less resistance) holding a live cable and you'll be well through thos pearly gates.
your body resistance is the same at ELV as it is any other voltage. difference being, less voltage means less current can flowSo would it be fair to say that the resistance of your body is much higher than the ELV (50V)?
on a normal transformer feeding our house etc, one side is connected to ground and used as an earth throughout. this side is neutral. the other side is the live (ignoring it being 3 phase for now). this live is at 230v between neutral and earth. touch this, and you will complete the path through your body to ground and back to tansformer.So why if I only touch one live will nothing happen? Sorry to sound like an idiot, it's just that I can't get my head around how if you did that on a normal circuit the RCD would trip but in this instance nothing would happen. headbang
