Snap their arm off... Mine was 25 meters and was about 1500 with the vat. Get a bloke with a mini digger to dig the trench first. WPD will give you a meter box and the ducting for free!! [once they have agreed the job and you have paid] Install all the ducting and the meter box. MAKE SURE you leave a length of rope in the duct so they can pull the cable through. You can backfill all the trench then. On the big day, someone will come along and dig a hole in the pavement and take all the muck away. Later the cable jointers will come and install the cable and connect it up. Later still, the lorry will come back and fill the hole in. Few days after that they will come and re-tarmac the pavement.
Thought this might help..
[SIZE=10pt]Here is what happens;[/SIZE]
[SIZE=10pt]The country is divided up into sections, and the wires in the ground are owned by the relevant “DNO” [The “distribution network operator”] Which in your case is Western Power Distribution.[/SIZE]
[SIZE=10pt]So, to have a new supply to a new building, you first apply to the DNO. They will then give you a quote for doing the work, and once you have signed the contract and paid, they will give you a “Supply Number” [Often/also known as an MPAN number. This stands for Meter point administration number][/SIZE]
[SIZE=10pt]Next:[/SIZE]
[SIZE=10pt]Now you need to appoint a “Supplier” of the electricity itself. There are loads of different supply companies. [i have chose “SWALEC”][/SIZE]
[SIZE=10pt]Then:[/SIZE]
[SIZE=10pt]You must contact your chosen supplier and give them the supply number or MPAN that the DNO [Western Power Distribution] gave you.[/SIZE]
[SIZE=10pt]The supply company will then register the MPAN with the DNO who will then arrange to come and install the cable to the new building, and the supply company [sWALEC in my case] will arrange to come and fit a meter.[/SIZE]
[SIZE=10pt]Anyway,[/SIZE]
[SIZE=10pt]Contact the chosen SUPPLIERS new connections team, and give them the Supply number [and arrange for them to be the supplier] and ask them to register the MPAN with Western Power Distribution, who will then come and install the cable.[/SIZE]
[SIZE=10pt]john...[/SIZE]
