a1
Forum Founder
- Feb 6, 2008
- 10,184
- -1
Hi all,
I have a strange onw with my Fiat Ulysse N reg, 2.0 Litre, petrol.
Mrs Admin, drove it to pick the children up before the school holidays, she called in the shop first and when she came out, the car wouldn't start.
She said that all ignition lights were on, but when she tried to turn it over on the key to start it, there was nothing happening. Not even a click - She could hear the "Injection system", but nothing else.
Mrs Admin, walked to school to get our children, and they all walked home, in the pouring down rain. I went down later to where she had parked the car, turned the key and it started. (about 2 hours after).
The same thing happened Yesterday, we used the car to go to town, no problem - we returned home, no problem, Mrs Admin then needed to pop back down as we had forgetten something. Then - you guessed it, the same problem - there was ignition lights, but nothing on the turn over on the key. Approximately 1pm. I went out to check again at 9-9.30 pm and it started. It started this morning too.
I connected a jump lead from the negatative terminal of the car battery, to the engine - to rule of an earth problem. Same problem!
If it was an immobilisor issue, then it would still turn over but not start.
If it was the starter motor, then one of the ignition lights would be "out".
I even rolled the car back, while in gear, in case the starter was jammed. But no, it wasn't that either.
The battery is new, and I can rule that out.
I even took off the double relay and had a look in there, but it all appeared well.
It is strange how it is intermittant, and only happens now and again.
Anyone have any idea as to why this is like this? Maybe one for Sindwinders friend?
C7uWS3jGgZM
All help is appreciated,
Many thanks,
Admin.
C7uWS3jGgZM
Many thanks,
Admin.
