hi everyone I have a question to do with a theatre light circuit all I have is a picture a college sent me showing 16 flexi cables with lighting plugs on the end which the school plug into a lighting desk, the school wants to switch to a dmx led lighting system, my question is I am not sure if the flexi cable runs up the wall into the ceiling to the plug sockets on the lighting bars, to switch to led I have to swap the existing lighting sockets on the lighting bar to conventional 240v plug sockets and at the other end all the tails that plug into the lighting desk to run into a new db box, My problem is can I extend the tails with more flexi to the db box or would I have to replace all the flexi cable with solid from the lighting bar socket right down to the new db board. I always thought that flexi cable was classed as none permanent and solid as permanent, is there any way that I can join the flexi to solid and still be with in the regs. As I said I only have a pic to go by, I am based in the midlands and my college is down south so I can not look for myself and if all the flexi has to be replaced with solid then its a much bigger job.
thanks
mel
thanks
mel
