- Feb 5, 2009
- 5,612
- 0
Is there anything stopping you from using this cable for normal tails? Or are tails alot cheaper?
Cheers
Cheers
tri rated is not DI and cannot be used as tails (unless in somekind of enclosure)Is there anything stopping you from using this cable for normal tails? Or are tails alot cheaper?Cheers
not as fine stranded as flex, but still a lot more flexible than singlesI understood this to be in an enclosure, if it is not then as you say tri is out, BTW tails are not di but insulated & sheathed.Flex as suggesred or tri & flexy conduit, depends on the space.
Its the copper strands that make tails stiff, the diameter of them, tri is fine stranded, like flex
