Last bit of work in the year all going well until you find a fault ....
1 light in a lobby
3 cables marked mains in , mains out and switch so simple enough arrangement
no voltage between loop and Live on the klick rose or at switch
disconnect all 3 cables from the rose and power up and as expected I have 240v across live and neutral on 1 cable so there is my mains in - I then power off and then do a continuity test to ensure I have the right switch wire and after testing I get a closed circuit, I then seperate the switch live and the live at the klick rose and test again and I first of all get open circuit and then second time I get a resistance so a bit puzzling......
Im hoping ive missed something simple.
kind regards
stephen
1 light in a lobby
kind regards
stephen
