Hi need some advice please.
Job is to feed 3 sofit spotlights and 2 security lights form garage, as this is best route.
Current set up is 2.5mm t&e to 13amp fcu, form this is what looks like a 2.5mm 3 core swa (possible 1.5mm) to an adaptable box in the garage (high level on wall), this then feeds a 1.5 t&e for a light. Also feeds a 1mm swa to a galv conduit t box, which feeds switch on wall and a fluorescent tube. Hope this is clear.
Thinking of changing this set up as need to take a feed out to feed 3 sofit downlights and 2 security lights. Not sure on where i am going to put the switch for the sofit lights yet!!!
The swa in the garage is old colours and not very neat.
Thinking of leaving circuit alone upto adaptable box in garage.
Replace adaptable box with bigger one, leaving the 1.5mm t&e for a light alone, but ripping out the swa that feeds the switch and fl light, and changing this to conduit, run this to a 4 way conduit box. out of bottom to feed switch, back up through top to fl light. Then carry on out of box with conduit, down the garage to a t box. Take a feed from this into porch for a switch for the sofit lights and back into sofit for the lights. then take another feed of this to power the 2 security lights.
it is a bit of a messy job, do you think this is ok, and do u think plastic or galv conduit is best.
Thinking of running singles in the conduit, i no this is not the norm for domestic stuff, i have a commercial background only.
Other option i was thinking was to replace adaptable box and take new swa's from it to feed the lights seperately, i.e 1 swa for sofit lights, 1 swa for garage light, 1 swa for security lights.
Hope this makes sense
craig
craig
