paul b b
Evening all.
just been to look at a job. guy wants lights in his drive and front garden. he is having a wall built around the drive as its dug into a bit of a bank. he wants them to work via pir. I thought of brick lights, are they any good? Do you put swa straight into them or ip rated box then rubber to light? Also the pir, it's gaining a tree so should I put an ip box round the back of the tree then rubber to the pir.
Any comments/tips/tricks most welcome
