How old before meters must be replaced
flatowner
Jul 17, 2015
7
London
I read somewhere that meters over 20 years must be replaced. But a friend says his is much older than this--the electricity company has not asked that it be changed.
What is the oldest meter out there? Can you be forced to change your meter--in my case the main fuse for my meter is in the flat of an individual who refuses to give access for it to be temporary taken out needed for a meter change.
Answers would be appreciated.
Thanks in advance.
I'm not sure what the age is, but it is worth noting it relates to the calbriation check of the meter, rather than the age of the instrument itself, meters could be swwapped out for a replacement, the old one sent back to the workshop, calibrated ans used to swap out someone elses meter, now in the days of electronic and smart meters, I'm not sure this happens much, but it can.
As to the isolation for your meter, chances are what would happen is the meter fixer would kick it back, reporting no access to isolate (they have a system to report different issues to the DNO, each with a number). The DNO would then have to look at dealing with the problem, that might involve a red isolation link next to your meter and as to how that gets fitted, depending on how its risk assessed, the DNO are allowed to work live in a lot of instances, or if they deem that they can't do that (too close to earthed metal parts, etc) then they do have a right of access to maintain their equipment, thats usually enough for most stubborn people to relent, if not then warrents can be obtained and they can enter with assistance of locksmiths and the police if required (thats they are sometimes required to do if they need to remove someones fuse becuase they refuse to pay the bill!)
Things will happen slowly if for a meter change, if the fuse blows and needs replacement, things would end up happening a lot faster!
Why is the chap being obstructive? Does he own the flat? or is it rented?/ HA? / Council? I know that when doing work on communial supplies located in one of the flats on council blocks, most of the obstructive folk are generally more receptive once the housing department spell out the fact that they'll not win by being obstructive....
meters used to be good for 20 years I seem to remember from the dark recesses of my memory.
Ypu cannot be forced to have a smart meter. The energy suppliers ae talking b/s about this because they are well behind target for fitting the useless devices.
I refused to sell my flat to the individual whose property contains the main fuse. He is using access to the main fuse as a means to pressure me to change my mind.
What do your deeds say about access to the main fuse?  Maybe worth consulting a solicitor - the one who did your conveyancing
