Robojin
- Jan 22, 2009
- 1,122
- 0
Have been asked to look at an installation as a favour to an old friend I have not seen for some time
When I investigate it seems that when the kitchen was installed the AGA in this house was connected to the kitchen ring :|
About 3-4 months back the fused outlet that the AGA (looks like connect by 26A flex to me, and can't tell if DP due to limited access) was connected to blew while they were out (only the AGA was on), so far as I can gather it was a partial melt, AGA service came out and replaced the SFU, and rightly pointed out that this should be on it's own supply, a fair point, it's also been tucked behind the units with access only from behind pull out draws, so takes a deconstruction to get full access
When I look at the board it's 3P, with no apparent spare MCB's, 3P is deffo an area I don't wish to touch as it's outside my competence
so the question is, "is it safe?", this has been in place for around four years, they have no idea why or can't recall if the engineer said why the FSU blew, the instructions state 30A on 6mm, yet the AGA guys seem to have wired with HR which looks like 26A
It's is on a 32A, but so is every other Kitchen appliance so I think it would be difficult even allowing for diversity not to overload the the MCB with everything on, yet in the two years since they moved in it has never tripped :|
Showing my lack on 3P knowledge, if a way were found to run a 6mm feed, would it need to be on the same phase due to the possibility of 415v, or am I confusing myself?
Just to reiterate I know this is not an ideal installation for a number of reasons but is it unsafe?
