Whats the difference between putting your connectors in a Choc-box or in your sandwich box (Tupperware), The sandwich box is cheaper and has been recycled.
I know no-one will agree with me, cos you have always been told it is wrong, but i dont have a problem with taped up chocblocks at all, as long as they are done well and show a degree of finesse.:| Tis my understanding that the BIG NO-NO was the old terminal strip wrapped in PVC tape & stuck up the hole in the ceiling... above a light...
But a round j/box? I cannot see a problem?
You painted a wonderful picture then !I know no-one will agree with me, cos you have always been told it is wrong, but i dont have a problem with taped up chocblocks at all, as long as they are done well and show a degree of finesse.imagine this; someone is doing a periodic and finds a taped up chocblock in the kitchen ceiling. Oh my god! call the emergency services, youre lives are at risk everybody leave the house immediately youre all going to die!!!
The electrician stands outside and fixes a danger of death sign on the door when the TLC 5th emergency service rolls up. The electric-paramedic jumps out swiftly and asks wheres the problem, the electrician then explains, and the electric-paramedic says ive got the very thing. He then risks life and limb by bravely going into the kitchen and climbing the fibreglass steps. He then with a bead of sweat dripping down his face calmely wraps a chocblock cover around the ticking time bomb of electricity. Then after finally screwing down the lid he goes back to open the front door to the gathered crowd, and says
Can you believe it, just because of this simple bit of plastic, We can all sleep safely in our beds.
Well if you are so scared of them... you just keep taping them up...So its totally wrong due to your inconvenience then. Sounds like a good point, it seems a jb is TOO EASY for someone to get at those dangerous terminals
Indeed Mr S!A joint box requires a tool to get into it, therefore compling with the Regs.
You need a tool to get under floor boards and into the ceiling, and a stanley knife is often quite good for getting tape off, but dont tell spesh.A joint box requires a tool to get into it, therefore compling with the Regs.
Same tool to pull a recessed ceiling light down to expose your tape joint!You need a tool to get under floor boards and into the ceiling, and a stanley knife is often quite good for getting tape off, but dont tell spesh.also wot tool do you need to spin off the lid from a ceiling rose?
So you agree then? you do need a toolSame tool to pull a recessed ceiling light down to expose your tape joint!![]()
