- Feb 10, 2009
- 342
- 18
I need to replace an existing door entry system.
Only one handset and one call button required.
The current one is a flush panel which mounts into a recessed back box - i'd like to find something that will fit into this back box. The original panel is about 85mm wide and 188mm high, There are two fixings holes @166mm centres. I don't know whether this is a standard size box or not?
The original panel has "Door Security Systems" printed on it.
Any suggestions would be much appreciated thanks.
