just because its plasterboard doesnt mean it was designed as fire rated, even though by its construction methods it is
Nope.The OP stated a plasterboard ceiling , so 1/2 hour fire rated at least,
Nope.Surely all the downstairs ceilings in a house are fire rated.
OP did state plasterboard ceiling in post 1...Nope.Nope.
I would disagree with that too unless someone can quote a regulation from the building regs.So without somebody looking at the building regs, are you saying that a plasterboard/skimmed ceiling on the ground floor of a two storey house is NOT classed as a fire barrier ?
Depends if it's a fire barrier or not. There may be a requirement for it to be fire rated in some circumstances, in which case it will be. Otherwise, it probably won't.So without somebody looking at the building regs, are you saying that a plasterboard/skimmed ceiling on the ground floor of a two storey house is NOT classed as a fire barrier ?
