did someone mention cookies? im on my way
Mostly people apply for an upgraded supply when their sparky advises that what they have isn't sufficient for their needs. I did an upgrade last week where the lady in question was having one of them mega bucks all singing and dancing cookers with an induction hob installed and her old 60 amp supply was upgraded to 100 amp. The mains cable will most likely be under the footpath and unless is more than one cable in there it's probably feeding that streetlight. (Additional fact for forumites; did you know that old PILC cable sometimes have a tiny 5th core just for running streetlights?Thank you for your input misssweden, very interesting. I will be around when they do they job assuming there is no charge as my neighbours wife seemed reluctant to want to pay out for it on the basis that they can't afford it at the moment. I would really like to know what prompted them to upgrade the fuse. UK PN said they had received an application from them so I don't think they have been reported as having an unsafe installation as I presume that would result in them receiving and official notice to comply . She's easy to talk to when it comes to things like this and you have to really interrogate her in order to get to the bottom of things. I find it embarrassing for her if you know what I mean so I will have to see if I can catch her husband in between his shifts. They had a shower installed, it's not electric and in a downstairs maisonette they will have had to have a shower pump installed so perhaps that is just one contributory factor.
Will UK PN's main cable be under the pavement in the street or under the road? There is a street light on the pavement nearby, will this be on the same circuit? Is this just a days work?
no, but i do know many overhead lines have a SL for the lights(did you know that old PILC cable sometimes have a tiny 5th core just for running streetlights?).
You have just highlighted how variable things are.Mostly people apply for an upgraded supply when their sparky advises that what they have isn't sufficient for their needs. I did an upgrade last week where the lady in question was having one of them mega bucks all singing and dancing cookers with an induction hob installed and her old 60 amp supply was upgraded to 100 amp.
The mains cable will most likely be under the footpath and unless is more than one cable in there it's probably feeding that streetlight. (Additional fact for forumites; did you know that old PILC cable sometimes have a tiny 5th core just for running streetlights?).
I make good chocolate chip cookies. Just sayin'...![]()
I have said on here time and time again, N power must be verging on illegal the way they go out of their way to persuade you that there is no fault and we are not going to do anything. and SSE won't take instruction directly if they are not the energy supplier.The difference there Dave is that a supply upgrade is a chargable job (at least it is in my area) where as in your case your customer would have probably needed a new supply put in at N Powers cost...
Yes but the problem with N power it they won't log a fault and pass it to SSE.That is bad. And as you say - potentially dangerous. I don't know how N Power operates, but my lot always have someone on rapid response to be able to get to customers as soon as possible when someone calls in with something like that.
It appears that things have been done backside foremost in that the re-wire was completed a few months ago. Does it not follow that if the supply was inadequate for his installation then the fuse would have blown by now or is perhaps a margin of safety factored into the sparkys calculations that is preventing it from blowing?Mostly people apply for an upgraded supply when their sparky advises that what they have isn't sufficient for their needs. I did an upgrade last week where the lady in question was having one of them mega bucks all singing and dancing cookers with an induction hob installed and her old 60 amp supply was upgraded to 100 amp.
Thanks for the re-assurance John, much appreciated.Hi Bob,
A fuse takes a lot of blowing... A 60A one, as is often used in the cutout, will take 200A for about a minute, and 100A for about an hour... So, as you can see, the installation as it is now, might not be ideal, but it was coping, even if technically, the supply was a bit overloaded.
"Overloaded" is possibly bit too strong a term here though, perhaps it might be better to say that it was coping with more than the designers originally had in mind...
If the fuse blows,[i presume it is a BS1361] you will not hear or see a thing, just next doors power will go off!!
john..
Thanks again John and Blue Duck. Interesting stuff about the already established easement. It's strange that there appears to be different rules for gas and water and sewerage. I know it's different in respect of water and sewerage as I keep getting flyers through the door for insurance in the event of a water pipe bursting or the sewer/drain collapsing between the street and the building. I have thought about the insurance but I'm not sure if it's possible to take out a joint policy with my neighbour. The water supply pipe and drains are probably still the originals so will be about 55 years old now.Hi Bob,
As the cable is there already, the DNO do not need permission, they have already established an easement. On most peoples land cert there is something about the free passage of cables pipes etc.. You cannot stop them laying the cables anywhere anyway. They will just get a court order and bill you!! So, do not worry about any problems, just sit back and get a better supply!! [For free!!]
john
I was there actually WITH the seal fairy last week................when the meter reader showed up!!!! They reported it to WPD. [who are not the least bit interested!!]
john...
We looked into that, came to the conclusion its a waste of money. For what we would have paid on premiums over the years, we could have paid the waterboard the money to fix it and still had some left over, and we are not moving yet.............. I know it's different in respect of water and sewerage as I keep getting flyers through the door for insurance in the event of a water pipe bursting or the sewer/drain collapsing between the street and the building. I have thought about the insurance
its not just london, iirc all shared pipes / drains are responsibility of local water boardIn London, if a sewer takes waste from more than one property (not including flats in the same property) then due to an agreement made by Thames Water in the seventies I think, it belongs to Thames Water, and they have responsibility for maintenance if it breaks or blocks. I have saved a couple of clients quite a lot of money by pointing this out.
