:OROTFWLROTFWLROTFWLlooking at the price of that rcd i nearly spat my creme egg out all over the computer![]()
Hager installation instructionsHas anyone got any diagrams how RCDs and main switches are wired up in a consumer unit? That would really help! Thanks!
What would you use the third core for in a plugtop?Thanks mateDo i need 2 or 3 core.
Thanks guys, I only queried the 2 core and 3 core cable bit because i asked my tutor and he didnt really give me a straight answer and just said that "all you need is live and neutral, RCD will protect your from shock" I thought this was incorrect and that you shouldnt rely on an RCD for protection and its for earth leakage anyway! So i was going to get a 3 core anyway and wire it up but just thought i would ask to double check.I will post up some wiring diagrams soon when i finally get all the bits i need.im reading this as hes not sure wether he needs 2 cores just live and neutral or 3 cores live neutral and EARTH (SO VERY IMPORTANT) You will need a 3 core flexibe cable whereby the brown will be a live conductor, blue will be your neutral conductor and the earth conductor will be your green and yellow wire
AaaaaH, thats not how i read it but i think you are right, phew.........!im reading this as hes not sure wether he needs 2 cores just live and neutral or 3 cores live neutral and EARTH (SO VERY IMPORTANT) You will need a 3 core flexibe cable whereby the brown will be a live conductor, blue will be your neutral conductor and the earth conductor will be your green and yellow wire
but without the earth, RCD will only disconnect once your the earth path, with the earth, RCD should disconnect before you can touch it (providing its a L-E fault)! i would recommend you find a new lecturer...Thanks guys, I only queried the 2 core and 3 core cable bit because i asked my tutor and he didnt really give me a straight answer and just said that "all you need is live and neutral, RCD will protect your from shock" I thought this was incorrect and that you shouldnt rely on an RCD for protection and its for earth leakage anyway! So i was going to get a 3 core anyway and wire it up but just thought i would ask to double check.I will post up some wiring diagrams soon when i finally get all the bits i need.
it should have read 'L-E fault', not L-N faultHow so? With an L-N fault the RCD will melt before anything. The lack of an earth has no bearing on the matter as it isn;t involved in the fault.
