however, in this case, the outer sheath only needs to enter backbox - doesnt have to go through to the 3 plateHello Mate,Yes - That is correct. Take the sheathing (Grey) into each accessory by a minimum of 10mm.
Very sensible using the RCD plug adapter Kiwi, even if you have to scrimp and save a bit on your clips & sheathing stuff at this stage, you have done the right thing investing in the RCD plug.Here are the pictures:
Hi KiwiHere are the pictureslease excuse the mess at the moment and also the lack of equipment, i have a very basic tool set consisting of 1 vde screwdriver and cable strippers
I have been doing 1 way lighting at the moment, basic but its a start, next will be 2 way lighting then what else? I have got some switched sockets so will do a radial. Maybe a spur when i get the hang of stuff.
Also, in the ceiling rose i have left the grey installation out of the rose but my tutor says that it needs to be in there a little bit, is this right?
Oh no !!Too much strongbow last night at leyton orient me thinks!
TLC sell it by the Meter. 99p for 1mm and
Phew -
Phew -
