southsparks
Came across a "tripping" problem today on a visit to a teaching workshop, a 5KVA "Blakley" transformer unit providing 110Volts to socket outlets for students, double-wound centre-tapped(as a site transformer,) fed from dis-board on 20 Amp circuit, with MEM/Eaton B-type RCBO. Am I correct in thinking it ought to be at least a C-Type, as current in-rush too much for B type?
This happens every few switch-ons on Blakely unit. Really only want to replace MCB part, and re-use RCD bit. Is it also possible
to swop-over RCD to new MCB, without damaging it? This would be a field-fitted job.
Had considered using a D-type MCB, but a bit wary, as not sure if E-loop impedance low enough. The transformer is less than two metres from dis-board and wired in 4mm I think. Not sure how they managed to use this transformer for six years or so.
Quite sure B-type breakers quite unsuitable for this sort of equipment supply, but would be grateful if somebody could confirm that for me.
Thanks.
Thanks.
