Hi I hope someone can help,I am a keen on diy but I have a real problem.
I am ok a well I have a water pump in the garage and also a new switch box.
I have a mercury tilt swich above water tank in loft housed in a green plastic box. Every time we have hot weather the switch fails and we have no water-I can use over ride in garage.
The tilt switch will not activate even if I get in loft and operate tilt manually.I have been told they cant fail but it clearly does every time it's sunny and loft gets hot. When cool weather returns it's fine again.
What's going on and what can I do about it?
I'm stumped thought about trying to insulate box from heat but not sure if that's possible.
Thanks guys,
Tricky1.
Thanks guys,
Tricky1.
