yes, on my morris
the bar that goes side to side at back from chassis to axle, stops the axle moving side to side
I can't see you getting much for it with lights on. What are the rules for auctions?Point taken about thee PUG I did have my doubts but thought I'd ask the question. Back to my car, given that the EGR is now blanked, do you think removing the stepper motor from the top of it and leaving it free of the mechanism will fool the ECU into thinking its actually moving the valve?
The thing is I can't sell it as it is and not sure I would even get away with trading it. ABS has to be the rear hub as it was never an issue until I changed both hubs last summer. I would be happy to get £2K for the car and just cut my losses.
I was thinking of black tape or taking the bulbs out :innocentI can't see you getting much for it with lights on. What are the rules for auctions?
:slapMy sister's car set on fire today (they reckon electrical fault) worryingly its the 2nd car she's had that's set on fire! You could always lend it her and the problem will take care of itself!
You were right the first time Revo , sorry to hear you're car problems .... Main Stealer may be the right road to take....unfortunatelyLatest update, ABS issues well and truly sorted. Removed the EGR valve completely and found all the electronics in the top of the stepper motor were burned out. As there is a sensor that reports EGR valve position back to the ECU then its not possible to run without it connected. I had no option but to replace the whole assembly. Found one online for £96 delivered so ordered it and stuck it on the car. Went to work and had one of the guys in the garage re set all the errors and all seemed well. Used car all weekend. On monday night the engine management light came back on and the car was working at reduced power.
Took it back to the garage and plugged diagnostics in. More EGR valve errors. so tonight I cleaned out the MAF sensors, throttle body, inlet, air filter etc and removed the blanking plate that I fitted with the EGR. Car starts and runs fine but when you get up to speed then come down again to a slow speed, the power loss comes in. Switch ignition off and re start engine and you get full power again.
so - start and run and its fine until you slow down then there is a significant power loss. Switching off seems to re set and there is power again until you slow down again.
I thought a new EGR needed some sort of re calibration but the mechanic at work disagreed. I'm beginning to think it may need to go into a main stealer - I mean dealer?
