motor cals help needed
searley
Sep 12, 2008
320
i have got this and need to no which equation is right if any ?
a transformer has 1000v (v pri) ans 200v (v sec).if the current (pri) is 5a,calc the secondary current ?
which way is right 1000/200 = 5 then 5x5 =25
or
1000x5/200 = 25
thanks for looking
i have got this and need to no which equation is right if any ?a transformer has 1000v (v pri) ans 200v (v sec).if the current (pri) is 5a,calc the secondary current ?
or
1000x5/200 = 25
thanks for looking
both methods work. go with the one you remember
You have the choice here, either use the voltage ratio, 1000:200 or 5:1 and if voltage goes down, current goes up by the same ratio (P=IV)
Or remember on an ideal transformer, power in = power out
so primary side 1000v x 5a = 5000w primary power,
secondary power 5000w / 200v gives 25A
cheers admin got the formulas you have put on here but looking for level 3 formulas.
That is the formula used in level three too Mate. ;)
When It comes to doing your 301. Make sure you know your motors, and your incuctance, capacitance and resitantace formulas. I sat mine last Wednesday and I had some crackers in there.
There was a beauty of a question on Lumer too. :(
:D
As soon as I get some time, I will put on a load of the level 3 formulas too.
can you remember any questions from your 301 and did you pass ?
cheers for the help with the formulas you put on the site they came in Handy
can you remember any questions from your 301 and did you pass ?cheers for the help with the formulas you put on the site they came in Handy
Distinction. :p
A lot of the questions are what you have been revising, just worded differently.
Thanks Mikey. Three and a half to go.
I have to do the paperwork side for the 302 as I have done the testing. :)
