p.mc
Hi I want to add 3 security lights to cover 3 areas of my back yard (3 side extension) with dusk dawn and PIR sensors including on/off timers for the lamps, so they will only operate at a certain light level, each have their own PIR plus lamp illumination timers.
Using 3 core & earth fed from a Switched spur unit and override light switch. Each light fitting will have a S/L terminal.
2 x Bulkheads 60-100w and 1 x flood 300-500w.
Can i feed all the fittings in parallel using 3 core & earth (Sensor feeds and S/L overide) with 1 x Flood Dusk Dawn/PIR/Timer and 2 x bulkheads PIR/Dusk Dawn/Timer and expect them to work as implied?
I suppose the only problem would be if there was no D,Dawn and timer adjustments on some fittings as some would come on at different light levels.or stay on permanent.
Please see image below...
http://s81.photobucket.com/user/npilcs/media/Lighting/Back%20Yard%20lighting%20and%20design.jpg.html]
[/url
![Back%20Yard%20lighting%20and%20design.jpg](https://proxy.imagearchive.com/614/6149377009208ace2ba4084124785051.jpg)
