My Name's Elle from Marshall Tufflex
EllesMT
May 2, 2017
2
East Sussex
Hi All,
I want to know from you guys, the installers, if you'd like to see specialist installation equipment from Marshall Tufflex? Whether it's a brand you trust? Or there's too many established brands already? Concerned about quality or price?
I work within Innovation in the organisation and want to hear from you not the wholesalers.  What do you want to see from a manufacturer, especially one that's be around for 75 years and British made.
Feel free to let us know if you feel something is missing from the industry and what we can do to improve it and make your job easier.
Thanks again,
Elle
It wouldn't bother me if tools had Marshall Tufflex plastered over them, the price would be the deciding factor  ;)
Nice to know your stuff is still British made.
Here's 1 idea, since the advent of metal domestic boards, fitting lengths of 2" or 3" trunking has become quite normal for me - it's easier than using TRS glands and stupid metal knockouts - I knock the lot out and comply with IP20 by using large trunking. So how about some ready made short lengths complete with end caps, sticky backed, saves carrying long lengths of stuff I don't use much.
That sounds stupid, they should just make boards that are installer friendly. Maybe they could use some sort of non-metallic material?
Sounds alright to me .  A pre - made length of 2 x2 or 3 x 3  PVC trunking with a series of oval holes punched out , that would fit on the top of an over - spec'ed  stupid metal board   & cover all the KOs .  With a ready fitted end cap .
The last board I fitted was an Eaton ...good board but had a load of 20mm KOs in the top where I think oval slots would be better  for  domestic use.
One Marshal Tufflex product I like a lot and is not readily available is their pre-made 90 deg.  conduit bend .  It doesn't have couplers glued on each end like some and looks far better than pulling  a hit & miss right angle over your bony knee .
Theres one I prepared earlier ...the bend is fitt at the top of the vertical conduit ...you can't see the join .
Cannot think of anything else at the minute other than asking a question of MT ( & others)  Why do the conduit adaptors have a useless bit of plastic moulding on them ...and why do conduit boxes have what appears to be an earth terminal moulded inside .  It gets in the way if you want to fit a locknut in there .  Totally un-necessary ...probably save a million £££s a year by updating the moulding.
Now that is a blinding idea.....
Not a new idea I think it was EGAtube who did it back in the 1980's. 450 - 600mm of 50 x 50 trunking with oval knockouts along each side and end caps it wasn't sticky back though
As EGA were swallowed up many years ago not sure it would be still made then again it wasn't a fast mover back then
Those metal boards are fine for industrial use ...utterly stupid for domestic  IMO.   They're OK if all the cables are rear entry .   I find myself looking at plastic boards now & thinking , how come you hav'nt burst into flames by now . ?
Metal boards or my installation methods @Lurch ? :slap
It is stupid, but having been given stupid metal boards I have foung the use of trunking makes life easier, it complies with regs, and it amuses me that it defeats half the object of metal boards. :innocent
TBF I often used a bit of trunking anyway, handy for dressing cables in when there's more than just a couple of circuits. My biggest issue with metal boards is the cable entries are terrible, and they all supply completely useless grommet strip forcing you to do it some other way, which is stupid because if you have to buy a consumer unit and then some sort of fitting kit from another manufacturer then that must the board is badly designed/rushed out after a knee jerk reg change.
Also, the bloody flaps that are hinged at the top, winds me right up.
So yeah, a bit of premade trunking would be handy, but it should come with the board, maybe be attached to it, like, I dunno, across the top panel. I don't even know we have non-combustible boards, not sure what they achieve, or why we can't have a plastic top for cable entry.
When Trump hits the Big Red Button that has Do Not touch written on it, after the smoke has cleared, there will be little or nothing left other than
cockroaches,
the bunch of W⚓️S that put us there in the first place
Estate Agents
Michael,from Microsoft/TalkTalk legal dept
wylex wooden boards
Certsure
A while back I put a MAPP Gas torch on a Wylex board
the board looked back at me and said "is that the best you have...bring it on!"
